sooo.. depends on driver? 0.oQuote:
lmfao!! maybe because the CU2 comes with an actual sub they were considerate by giving an extra 8kw thinking it would slow the car down.
When it comes to drag racing a car to compare side by side it all depends on these factors:
*are you stupid enough to put E10 in your car?
*did you try to add fuel and oil additives to your car for better response?
*do you have the luxury model that has all the heavy fancy gizmos?
*are you racing with a full tank of fuel or 1/4 tank of fuel?
*are you a fat guy racing a euro against another euro driver that's a midget?
*did u cheat by removing ur spare tyre from the boot?
_________________________________
on a more serious note
the compression is much higher in the CU2, so i am "guessing" if you got the CU2 pistons & exhaust & headers into a CL9 and getting it tuned it might just match up. Of course you could never justify the cost in a project like this just to match a CU2.
if you got a standard CL9 & CU2 side by side it would be an interesting to see the results.
