I had the same problem. Fluids were fine and everything. I got the clutch replaced and that didn't fix much. I found that it was my clutch pedal bracket assembly. It has very thin metal so it may snap easy. It might not be the problem but check it out before you think about getting a new clutch. To test it, just jump in your car and press on the clutch, if its very soft and feels like there's no pressure what so ever then that's the problem.
