Originally Posted by
ks_87
for bleeding you can buy a little bleeding tool from repco/supercheap that turns the 2-man job into a 1-man job - I used it to bleed my clutch. just a tube with a one-way valve on the end that stops liquid (and air) going backwards through the bleed point back into the system. Wouldn't really recommend bleeding brakes without supervision if your noob though.. definitely don't want air in the brake lines.
