i would not recommend jamming the flywheel/flex plate as i have seen to many amateurs do this and snap teeth off the ring gear
Not an Asian lol I think I would have enough strength for a breaker bar but gotta find one. Heard about the flywheel way too but I don't wana mess with that cause I'm not the most experienced lol. Thanks for the ideas/help everyone :)
$15 - $20 from auto shop will do the trick,
should :I
put the car in gear and get someone to press down on the brakes aswell, and then try to undo it?
Already tried the gear+brake way, didn't work :(
man up and put more muscle in.
Don't need to buy a breaker bar, just use a piece of pipe and slip it over the ratchet. If you don't have a piece of pipe, use the handle of the jack. It should fit over the ratchet handle.
by doing that you will definatley break the ratchet.
