need a tune too.
need a tune too.
where can i get hondata from? and how much is it? are they similar to like a apexi power fc?
Op, for the money you spend on a jdm ecu, jdm 4-1 (98spec) headers and cat (im pretty sure the cat is exactly the same 2.25" and stainless steel) u may aswell put in a bit extra and get ur self some used good aftermarket headers with a 100cel cat. Keep ur audm ecu, with out a tune u will have more then 147 at the flywheel.
Then free up ur cat back with a mugen twinloop or wateva exhaust u want. Then Buy urself a hondata and tune it and ur lookin at 120-130 kw atw, which would prbz be around 175-180kw at the fly
http://www.ebay.com.au/itm/Hondata-S...item19c9359350
if you need an ecu
http://www.ebay.com.au/itm/BLACK-ECU...item20be025828
might also need od2 to obd1
http://www.ebay.com.au/itm/OBD2A-OBD...item41571090b3
thanks for all the info guys, given me something to look into
I ment cat-back* my bad
Ah okay. I've got both jdm and adm b pipes here. Yet to do a full measure up, but I suspect they are the same other than the obvious length difference and the extra resonator on the jdm
audm catback is stainless.
