2 pistons rings are bad, so i want to change rings, I do not want to take the engine out. I want to take the head out and pop the piston from under and change the rings to a new rings and keep the old pistons. Will that be a problem?
I also was thinking to get higher compression pistons with ring, since I will be taking the pistons out, but the problem is the sleeve will have different shape than the new piston, so i am worried of doing that.
