thats how much it is... a good exhaust will cost more than that and headers almost double
the acceleration from changing the diff ratio is better than any na mods you could do
wait until your diff goes before you change your final drive, they're a ticking time bomb anyway :P
I love them! They chew through rotors, squeel on hot days and have heaps of dust but performance wise the initial bite, ability to hold high temps, maintain pedal feel are almost flawless. Very consistent pads..
I would recommend buying them directly from Japan. Front and rear set will set you back about $500 :) PM me if you need a contact.
But otherwise I get my rotors through OTR too.
A K&N FIPK kit or even a Injen/Fujita will set you back about $500 from memory and exhaust anywhere from $500 to up to $4000 :p
So a FD with just the drive part may be cheap in comparison, the labour will be atleast $600 if you take out the diff yourself... But theres still the Honda diff rebuild parts on top of that. Then a yellow box is needed to correct your speedo as it will be off after install. Then you also have to decide of you want to upgrade to an aftermarket clutch type diff... or a higher capacity rear diff casing (most failures are due to incorrect/bad installation or breakdown of fluids due to heat because of limited fluid capacity in the first place).
Like Tamay said, I'd would wait for it to break before doing anything... except I've been waiting a while haha.
ohhh okay :)
Put a front lip is the first thing I would do, it makes your S so much better.
If you dont care about the out look, go for an intake and exhaust would gain a bit power and make it sound better
okay ive decided to rather just waste money on a Air filter, im gonna get a CAI (either AEM V2 or K&N).
Cant decided which one as both have thier advantages,
anyone got any ideas?
There are alot of post for CAI's. Google is your friend.
Yes i know that...
http://www.s2ki.com/s2000/topic/6344...intake-thread/
I was just wondering what OzHonda members thought.
Would be good to have a few people update the wiki:
http://www.ozhonda.com/forum/showwiki.php?title=S2000
Lol I'll pass. Yeah don't know why Honda didn't learn from Nissan's diff design... Those things are indestructable :D Well almost... I've been babying my diff cause of all the stories I hear :p
Imo regarding the Intake, I went with K&N because of reputation, design (Not likely to get water sucked in) and gains. The AEM looks cleaner but given Melbournes weather, I didn't want to risk driving through floods and suck some water into the cylinders in the process...
Ive recently purchased a K&N FIPK and now waiting for it to be delivered.
Thanks for all comments and information, will update on how it goes.
