comp test takes a few 5 minutes so it shouldn't be costly. You remove the spark plug and unplug the injectors then screw in a compression gauge and crank the engine to see how much air pressure it can withstand. Then tell us how much each cylinder held here and someone will be able to tell you if you're ok or not.
