ok will replace it today see if it works thanks for the help. i bought some start ya barstard so ill see if that helps aswell lol
Also swap the plugs over and make sure the firing order is correct
got it going i sprayed start ya barstard down intake-massive back fire burnt my hand so i pulled the dissy apart was all cracked and metal shavings everywhere swapped it with mine but its obd2 so swapped the loom plugs and it started straight away, then i stepped on the imobilizer button and broke it any way to get around imobilizer :(
GJ with getting it started, but seriously mate, sounds like you've got the best of luck on your side atm haha.:p
