sharing what i have gathered.
PART NUMBERS
- 17121-RRC-000 :FD2R IM Cover
- 17100-RRC-000 :FD2R IM
- 39152-SR3-A00 :Antenna block off plate
- 91631-SR3-000 :AC firewall plug
- 08U09-SR0-110A : Armrest with cloth lid (black)
- 79500-SX0-A03 : Black climate control (from honda odyssey)
- 08W42-S2A-100 : S2K Black lock nuts
- 90304-SA7-811 : S2K nuts
- 78512-S03-Z70ZA: Steering wheel cap cover (DC2R/EK9)
- 46930-SR3-013: Clutch slave cylinder
- 46920-SR3-A01: Clutch master cylinder SR3 (Civic 92-95) - 5/8"
- 12342-PT2-000: spark plug rubber seal on valve cover
- 30110-PA1-732: Distributor O-RING (26.4X3.1) (TEC) D15B VTEC
- 52385-S21-003: RTA bushings Civic/Integra. OEM
- 15825-P08-005: VTEC solenoid gasket (Head to Solenoid) for D15B VTEC/D16Z6
- 36172-P08-005: VTEC solenoid gasket (Upper one inside, right under solenoid) for D15B VTEC/D16Z6
- 30530-PRB-A01: K20A knock sensor
- 21351-PR3-010: B18B flywheel cover (to clear 4-2-1 type header)
- 91006-634-008: B series pilot bearing (use OEM as aftermarket are said tend to fail prematurely) NTN, Koyo etc.
- 22810-P21-003: B series mainshaft release bearing (use OEM as aftermarket are said tend to fail prematurely) NTN, Koyo, Fujikoshi etc.
- 38920-P73-013: B series ac belt - B18C5
- 14400-P72-014: B series timing belt - B18C5
- 56992-P72-004: B series ps belt - B18C5
- 31110-P73-A01: B series alternator belt - B18C5
- 22810-P21-003: B series clutch release bearing 45.40
- 22841-P20-000: B series shift fork boot 11.00
- 91006-634-008: B series fly pilot bearing 15.13
- 17130-PM6-003: B18C7 PCV Valve
- 11855-PR3-000: B18C7 PCV valve hose (goes to block)
- 19301-PAA-306 or 19301-P08-316 : B/D Thermostat unit (B series/D series interchangeable)
- 21350-PRB-000: K series clutch cover case 8.08 - K20A
- 22810-PPT-003: K series clutch release bearing 33.76 - K20A
RSP IM part number Civic Type R FN2
Intake manifold 17100-RSP-G00
Other half of the plenum 17101-RSP-G00
Gasket for the "power plenum" 17102-RSP-G01
Additional runners inside the plenum 17103-RSP-G00
EG6 Black interior part numbers
83533-SR8-960ZA LINING, R. DOOR (GRAPHITE BLACK) $245.27
83583-SR8-A30ZA LINING, L. DOOR (GRAPHITE BLACK) $237.92
83503-SR3-010ZB LID, R. DOOR SPEAKER (GRAPHITE BLACK) $18.66
83553-SR3-010ZB LID, L. DOOR SPEAKER (GRAPHITE BLACK) $18.82
83504-SR3-000ZA POCKET, R. DOOR (GRAPHITE BLACK) $28.57
83554-SR3-000ZA POCKET, L. DOOR (GRAPHITE BLACK) $28.57
83521-SR3-G00ZA POCKET, POWER WINDOW ASSISTANT PULL (GRAPHITE BLACK) $15.35
83511-SR3-G00ZA POCKET ASSY., POWER WINDOW MASTER PULL (GRAPHITE BLACK) $15.35
Carpet
83302-SR3-A20ZA CARPET (GRAPHITE BLACK) $318.11
84251-SR3-000ZB GARNISH, L. SIDE (GRAPHITE BLACK) $28.19
84201-SR3-000ZB GARNISH, R. SIDE (GRAPHITE BLACK) $28.19
74881-SK7-A01ZA COVER, TAILGATE OPENER (GRAPHITE BLACK) $11.06
74882-SK7-A01ZA OPENER ASSY., TAILGATE (GRAPHITE BLACK) $25.68
84231-SR3-000ZB TRIM, FR. OPENING (GRAPHITE BLACK) $32.17 x2
Side Panels
83730-SR0-A21ZB LINING, R. SIDE (GRAPHITE BLACK) $74.13
83780-SR0-A21ZA LINING, L. SIDE (GRAPHITE BLACK) $75.61
83736-SR3-900ZC LID, TAILLIGHT (GRAPHITE BLACK) $9.33 x2
83735-SR3-000ZB LID, R. SHOCK ABSORBER MAINTENANCE (GRAPHITE BLACK) $4.14
83785-SR3-000ZB LID, L. SHOCK ABSORBER MAINTENANCE (GRAPHITE BLACK) $4.24
83746-SR3-000ZB CAP, SIDE LINING (GRAPHITE BLACK) $4.77
83737-SR3-900ZB LID ASSY., R. RR. SPEAKER (GRAPHITE BLACK) $22.71
83787-SR3-900ZB LID ASSY., L. RR. SPEAKER (GRAPHITE BLACK) $22.96
Hatch Panel
84440-SR3-003ZB LINING, TAILGATE (LOWER) (GRAPHITE BLACK) $68.03
84441-SR3-003ZB LID, R. TAILGATE (LOWER) (GRAPHITE BLACK) $7.18
84491-SR3-003ZB LID, L. TAILGATE (LOWER) (GRAPHITE BLACK) $7.42
84640-SR0-A00ZB LINING ASSY., RR. PANEL (GRAPHITE BLACK) $66.26
74853-SR3-003ZA CASE, GATE HANDLE (LOWER) (GRAPHITE BLACK) $6.64
74854-SR3-003ZB KNOB, GATE HANDLE (LOWER) (GRAPHITE BLACK) $3.82
Dash Components
77299-SR3-C01ZA COVER, CENTER (LOWER) (GRAPHITE BLACK) $34.47
77710-SR3-003ZA ASHTRAY, FR. (GRAPHITE BLACK) $31.79
77295-SR3-C01ZB POCKET, CASSETTE (GRAPHITE BLACK) $10.02
77500-SR8-A95ZA BOX ASSY., GLOVE (GRAPHITE BLACK) $111.48 (SRS)
77500-SR3-C01ZB BOX ASSY., GLOVE (GRAPHITE BLACK) $91.77 (NON-SRS)
Console
83416-SR3-023ZB CUP HOLDER (GRAPHITE BLACK) $77.22
83412-SR3-000ZD CONSOLE (GRAPHITE BLACK) $79.80
83412-SK7-000ZA CAP, RR. CONSOLE (GRAPHITE BLACK) $3.70
83441-SR3-000ZA CONSOLE, RR. (GRAPHITE BLACK) $76.95
88320-SB3-950ZK ASHTRAY ASSY., RR. (GRAPHITE BLACK) $17.94
