		Dodo Juice Supernatural Leather Cleaner Spray is now available along with Dodo Juice Supernatural Leather Sealant Spray
Dodo Juice Supernatural Leather Cleaner Spray is a soft water-based formula to gentle clean leather surfaces including trim and seats. Made with a blend of mild solvents and soaps that will remove dirt and contaminants including clothing dye transfer. This residue-free Leather Cleaner will leave your seats with a satin-matte factory like finish.
Dodo Juice always recommend protecting your leather surface after cleaning with a good Leather Sealant such as the Dodo Juice Supernatural Leather Sealant.
http://www.carcareproducts.com.au/im...s/wz63pctt.JPG
and
Dodo Juice Supernatural Leather Sealant will provide on-going protection and conditioning of your leather to help prevent premature aging and wear.
Some oil & wax based protectants can trap contaminants into the grain of the leather degrading the finish and causing, ugly cracks, aging and wear.
Dodo Juice Supernatural Leather Sealant Spray will not only condition, protect and repel dirt and other contaminants it will also allow the leather to breath, resulting in fewer cracks and wear and therefore keeping your leather looking as it did when it left the factory.
Use Dodo Juice Supernatural Cleaner before applying Dodo Juice Supernatural Leather Sealant Spray to ensure all contaminants and dirt have been removed from your leather surfaces which will ensure a full bond of the sealant.
http://www.carcareproducts.com.au/im...s/9u4ufakf.jpg
		Dodo Juice Basics of Bling Detail Spray Concentrate (Refill), 1 Litre Concentrate
Dodo Juice Basics of Bling Detailing Spray (Concentrate) is a water-based detail spray that cleans and shines all surfaces. This Detailing Spray can be used to clean up light dust, bugs and road film, and even used as a waterless wash that will leave your paintwork glossy and smooth.
Use Dodo Juice Basics of Bling Detailing Spray regularly to restore that freshly waxed look leaving your paint-work protected between washes from contaminants. Best of all, you can use this spray immediately after you have waxed or seal your car due to its water-based formulation. Simply spray onto the surface and wipe over with a Microfibre cloth and buff off to a slick finish.
This 1 Litre Bottle of Basics of Bling Concentrate (Refill) makes 10 Litres of Detailing Spray to ensure you never run out of your favourite Detail Spray!
		Buff & Shine Microfibre Pads (Cutting & Finishing Available)
Cutting Pad;
http://www.carcareproducts.com.au/im...s/fawbh8s2.JPG
The Buff and Shine Microfibre Cutting Pads have been manufactured from the highest quality European foam and soft, plush durable microfibre in the USA. This MF Cutting Pad allows removal of medium to heavy marring & scratches* from your paintwork quickly, easily and safely.
Finishing Pad;
http://www.carcareproducts.com.au/im...s/bjecemfp.JPG
RUPES Polishers Sampler Kit
The RUPES Sample Polishes Kit features all 4 of their polishes, giving you the experience of the full range of RUPES Polishes without having to purchase the full 1L sizes. Each Polish provides a different level of cut, gloss and finish. Allowing you to do every stage of polishing on your paintwork.
http://www.carcareproducts.com.au/im...s/rcxy88fg.JPG
Einszett 1Z Tar & Grease Remover Aerosol
1Z Einszett Tar & Grease Remover Aerosol can be used as an engine cleaner, tar remover, pre-cleaner on paint and also will dissolve grease, tar, waxes, tree sap, adhesive residue and other greasy deposits from your paintwork, wheels and more. Very handy to spot remove tar from wheels, body kits and so forth.
http://www.carcareproducts.com.au/im...s/fayx9tyu.jpg
