Just remember, if you're letting your car warm up by ideling for 20 minutes, that means only the engine will be warmed up. Gearbox/diff need time to warm up as well.
Another thing to consider re your oil consumption is you PCV.
U are right , by gosh !
Back on topic.
Have you considered a leak down test to find exactly where there is , if at all there is a compression leak ?
I did think about that but I dont have the equipment to perform one. :(
although after talking to adrian I think it should be fine, I think it's just the valve guides that have wear on them. so once I do the rebuild it should improve.
