Nah they are the same part numbers for Australia too
To OP:
I'm currently using the Eibach Koni yellow setup you are contemplating on getting, and thoroughly recommend it. Dunno what's going on with the exxy shipping, but it is definitely available for 900 shipped from Shox, as a mate got it not too long ago. Though I did contemplate coilovers (mainly for the ease of adjusting the height), I went with a shock and spring combo that was proven and of great quality. Damper adjustability is great and dead easy but full soft is waaaaay toooo sofft, I've basically got mine on full hard setup front and back. If your just using for daily drives on the roads, then it's all you need.
Hope that helps somewhat
You may need to get a rear camber kit depending how low the new setup makes it.
It has perches which means you can lower it but due to the rake i think consensus is your rear is on lowest perch your front on lowest perch to give minimal rake
there is height adjustment but its not much, i was reading on another forum and it said It can go up and down about 20mm (about .8").
http://www.tsxclub.com/forums/1st-ge...djustible.html
Yes they are height adjustable.
I got a suspension shop to install mine, as it is something I have no expertise in mechanically, and wasn't feeling confident to do a DIY job. cost about 350 including a full wheel alignment.
definetly leaning towards the koni and eibach springs from show.com now. Currently overseas so still have some thinking time. Will most likely decide when i get back to Australia. Thanks to everyone for the helpful info =)
Yeah I am considering getting the Koni shocks too to couple with the Tein S.Tech springs i currently have. HeeltoeAuto has them for $750 landed which is not bad i reckon. Good luck and post pics once you get'em :)
so hows you get 750 landed? i did it and it turned out more expensive than shox..com landed. so tempted if its cheaper !
