Most, almost 80% of panel shops here use
Farecla. Its very good and quick.
Any cutting pad will do but it depends on the method you use.
If doing full cut and polish here are very brief and simple steps.
1. Rub back full car in 200 paper removing all peel and avoid cutting through the clear
2. Clean and dry full car
3. Use Lambs wool cutting pad with coarse cutting compound. This is to remove the sanding marks
4. Clean all left over cutters on the car.
5. Repeat step 4 until all 100% of sanding marks are gone.
6. Use very fine cutting compound with a white foam cutting pad to remove swirl marks left from lambs wool.
7. Repeat step 6 until all swirl marks are gone.
8. Use Polishing/Glaze with a black foam pad to remove any minor marks left from cutters and/or cloths.
During each step rinse and clean your microfiber cloth. Be sure to use a brand new cloth after polishing.
Note: If your car is black.....Do not do this as it is virtually impossible to cut a black car without marks left on it.
