Farkkk i wanna go vtakking!!!
Google knows all! Use it.
Quote: Originally Posted by Bludger wat?? Because the cams spin at half the speed of the engine, so 1000rpm higher cut off = 500rpm more for the cams
Quote: Originally Posted by spetz because the cams spin at half the speed of the engine, so 1000rpm higher cut off = 500rpm more for the cams wtf??
Quote: Originally Posted by Bludger wtf?? i think he means if the rev limit is raised by 1000rpm the cams will be spinning 500rpm faster then previous rev limit.
Quote: Originally Posted by mocchi I thought camshafts rotate at half speed of crank? if at same speed then e.g. int valves would open everytime piston goes tdc? Mocchi is correct.
mind is full of fuk
Quote: Originally Posted by u mad? mind is full of fuk http://www.ozhonda.com/forum/customa...ar28865_10.gif
