Ok..
Let us knw how u go..
Most likely just a jumpering pin or a programming feature on the module unit.
Just remember that sometimes remotes can reset themselves after a battery change.
My amp remote does this, must reprogram after changing the batteries.
My Air con remote at home did the same thing too, reset all the settings after it had dead batteries for a bit.
how annoying... i had a look at how to reprogram and there were some rituals online but nothing has worked. i will chat with a honda dealer and see if they can help
had the same issue, honda wanted $880 to replace both actuators and that was only a guess. I took it to an auto electrician and he said that the signal wasnt being recieved and my best option was to buy a whole new aftermarket alarm as it would be more expensive to fix the Honda system.
thanks it looks like i'll have the same problem. i've found signal works every now and then so remotes are still sending and codes are still on but receiver may be dodgy. aftermarket sounds like the way to go
