You'll be fine seriously. Just carry a screwdriver for the clamp. Those $10 tool kits are worth keeping in your car ftmfw
you can always get a hydro shield for your injen but it wont protect it completely, simota whale penis sounds good but heat sucking straight in
I hope you are aware the whole filter has to be submerged and the whole system airtight for it to suck water up. Because water is heavier than air if the filter isn't completely submerged urge air will still come thru. But aem have a solution. It's called a cold air bypass it replaces the silicon connector somewhere higher up I.e. stock filter location., would be much easyer to just use that then replacing the whole intake
Hydro shield you say...
http://img27.imageshack.us/img27/972...2706314611.jpg
Bugger that....
I don't know where your filter sits, but I had a similar concern with my old ek1 (floods alot along my road 15-20 cm) and my filter was only fully submerged once and the aem cold air bypass saved it. Well worth it in my option for the wet months.
http://img.tapatalk.com/31b4d85f-06b3-1d1e.jpg
http://img.tapatalk.com/31b4d85f-06bc-e8f2.jpg
if your that worried just wait until someone else goes threw the water then skick right up the ass useing there wake to keep your cia from water?
when i owned my bravo i use to hammer threw water and id have a number of small cars on my tail lol
