lol...
started my b16 with a d15b7 ecu YO for extra bisi cam work to it
Waltzing Matilda
vtec pls
sighh... lol :(
well im hoping that, that is all my issue is.
thanks for your help guise.
got the car started today, and guess what.... WITH THE D15 ECU.... problem was simply not enough fuel. earlier in the week i had put $15 in it, as i drained all the other old fuel out, and it simply wasnt enough fuel in the tank :)
was wierd that the fuel was coming out the filter, just wasnt enough i guess :)
all i need now to drive it is the following :)
TORQUE MOUNTS
POWER STEERING BRACKET ( not neccessary )
AIR CON MOTOR ( not neccesary )
CAT BACK EXHAUST (have one in dubbo but will probably just get one made here)
EXHAUST MANIFOLD GASKET
INTAKE
TOP RADIATOR HOSE
STEERING COLUMN PLASTICS
The other weird thing i need is the washers for the stabilizer bar for the gear shifter, its 2 big washers that go on either side of the stabilizer bar on the gearbox side.
There is a few other little bits and pieces but ill update those later
