You must spread some Reputation around before giving it to trism again.
This appears to also be a common problem...
And yes, thermostat sounds like the answer... Make sure you get the right one though... there are different versions from what I've gathered... mine is not letting the car heat up as much... so it'll open much earlier... I'm told there is summer and winter versions, one opens before the other...
