It's a 96 integra my mistake
It's a 96
ok update, theirs no spark from the sparkplugs any of them, dizzy cap looks good cleaned points and everything. maby when i washed the engine i blew something the fuse that blew was the backup in the engine bay but i think that was something to do with another thing. the abs light,battery light,and the hand brake light show on the dash at all times when battery is connected even with the key out of the ignition, as soon as the battery is connected those lights show up the blinkers also work with the key out. has anyone got any clue what it could be, dash lights on-no spark from any of the spark plugs
Your friend obviously doesnt know much about cars, you should never get water in the combustion chamber no matter how little amount, you should of taken the leads off and blast out the water with compressed air,dried out the spark plugs and leads and then check nothing shorted out (blown fuses etc)
hope you learn for next time engines and water dont mix
take it to a mechanic instead of hoping someone can diagnose your problem over the internet without touching a tool or your car
The problem could be the dizzy
The problem is the icm...
