Thats true Weq, but given that he has posted this in the ALL MOTOR section, i'd say he doesn't want to go Turbo. So lets keep replies to NA shall we :)Quote:
Originally Posted by Weq
That said, i'd go for the following in this order:
1. 4-1 JDM or Mugen headers
2. 2.5" Mandrel Bent full exhaust
3. CTR Cams or Jun Cams if you have the $$$
4. Aftermarket ECU like and Apexi PowerFC or Hondata
Those will probably be just less than the 5K mark. As a rough idea. If you want more detailed info, post back.
Also, #1 is where you should be very carefull and i'd recommend dishing out the $$$ there. As for the cams, it really depends on what you are after.
