why don't you check for current draw?
I didn't think I'd have to coz there's always a voltage when I try to start the car.
Also as soon as I switch the car off the dash clock resets
Thanks, will check in the morning.
7.5amp back up fuse is fine and so is all other fuses in the bay
got a multimeter onto it and tested the altanator,
with all electrics on including heater, dimister, lights and high beams and hazards the voltage dropped from 14.4 volts with nothing down to 11volts then the car stalled.
but starts right up again
it was probably fine for the first day since the battery was fully charged, seems like your alternator is on the way out.
Update
Got to work today, switched the car off and thought id see if it would start..
Nothing happened, car wouldn't turn over, interior lights wouldn't go on, hazards didn't work, headlights didnt..
Like there was no battery even connected.
So I moved the positive and negative terminals on the battery and it worked..
The problem must be there..
must be the accesory wire/ ignition wire, clean all terminals and earth points
No they were obviously properly hooked up since I drove the car..
Just when I switched it off it wouldnt start again till I moved the terminals, like giv them a wiggle
Bump,
Had the alternator reco'd and new ground wire from battery to chassis put it problem has gone so far!
Hopefully lol
