One thing i've noticed alot better is handling believe it or not. but my old mounts were completely gone.
haha so u can feel the differents straight away what mounts did u get?
I put hasport 88A's in. Before with the worn mounts when reversing you could feel the engine "lift up and forward" and when "tapping" the accelerator when driving I could feel the engine move and you could feel it in the gear stick to, Also when concerning hard from left to right ect you could feel a weight shift at the front or when going fast over a bumpy road things just didnt feel solid.
Now its simply just awesome, I've always done the mounts on all my cars, FWD need to have strong mounts if your gonna drive hard. only downside is my entire car rattles and shakes like crazy, but hey its worth it.
yeh my car does the same thing when u hit the acelerator on and off u can hear the motor moving badly and some time its gets stuck trying to put it in gear also?
but yeh im gunna get good one i buying hasport street 60a mounts cause its a daily and i sometimes go to the track or drags
replace rear and torques
Sorry to slightly high-jack your thread but does anyone know where to buy more solid torque mounts ? I want to replace them also, but the Hasport intructions say the torque mounts can be removed for a "cleaner" look.
They remove them for exactly that (good excuse by Hasport cause they don't make them): They clean up the engine bay looks a little by deleting them. The engine just depends on the 3x engine mounts then. A lot of people remove the torque mounts after they do a engine conversion as well, for the same reason. Removing them just puts extra pressure on the other mounts, especially the rear mount when accelerating and under load as the engine wants to rotate.
The torque mounts do exactly that, they are right out front of the engine and they limit the amount of engine rotation/torque.
Avid do solid rubber torque mounts for your DC2. So look them up.
End up doing it op?
just wondering if you cant do this all by yourself, how much would it cost to get a mechanic to do it? this is including the mechanic buying the mounts, labor etc. would this be a days job or longer? thanks
Probably $600-1000
For all mounts
My mate said he was quoted max 10 hours labour for his dc5. I did it for him on the ground in less that includes wasted tIme due to receiving the wrong rear mount.
