Originally Posted by
mugen_ctr
the amount of turbo ignorance on here....
Firstly, u can run a turbo b18 fine for a DD fine. YOU dont need internal work done so long as u keep it to a safe power level, RESEARCH IS THE KEY HERE
2ndly Jump onto honda-tech.com plenty of ppl have done B18 turbo an ran em fine with zero issues and on stock block
3rd, YOU DONT NEED a expensive build, again research is the key, ozhonda would be the last place id look for turbo information, considering the amount of N/A builds on here
4th IF ur car is a OBD1 ecu which i assume it is, chip it, HONDATA S100 is the go, or find a pre-exisiting odb1 chipped ecu, such p28, p30, p06 etc etc, shouldnt cost no more than 250 max!
Depending on the tuner and engine condition, power could be anywhere from 130kw to 160kw, if the tuner does his job really well, the turbo engine can last a life time
