Sorry this is off topic question, would that dimension fit on a cl9?
what is the correct offset and ive been told i should get 235/35/19 or 245/40/19 .. offset of the wheels come in +35 but i was told by a friend that if i dont want to run with spacers to get +30 thoughts? the wheels im getting are these.
http://bsawheels.com.au/products_clo...t_no=943&Name=
Depends on what kind of look you want, like for example concave or not,
Also some people run with spacers is because of the design of the wheel where the spokes dont clear the calipers, but with the look of these wheels it should be fine.
Also what kind of width of the rim are you going for?, cos this will decide what tyre suits it best
Hope this helps!
Ok, so I guess my question is also about wheels for CU2, since the rears are quite IN, will I need to look for staggered wheels to keep that Flush look? or should I run spaces because then I can interchange the wheels for wheel rotation? This stuff is doing my head in... When I think about my car, my workplace productivity drops below ZERO :S
Hahahah same here when thinking of what wheels to put on the cu2 lol..
umm First of all anything above 35 offset would would be no probs for the rear, will fit tight and sit quite flush with guard.
Also as said above if the wheels are no lower than +35 it should fit all of the wheels with minimal work for the front, probably a camber kit and not sure if need guard rolling.. dont think so
Hope this helps!!
does 235/40R18 fit the Cu2 wheels??
Just curious to know if the following rim width and offset would fit 18x9, with offset of 40
