was stated in the first post "Running -2 deg camber front"
After stealing another friends 22mm swaybar for a 2 days over the weekend the problem has been pretty much solved. The thicker rear sway on its second adjustment has helped alot more than the one set adjuster that was previously on the car. after a bit more mucking around and now running 2mm toe out up front and 0 toe at the rear, re adjusted the dampers in the coilovers and including with the previous camber and castor the car is running much better (which means i can now focus back to my own s14) many thanks to the helpful suggestions. Almost tempted to go buy a civic of my own now :)
