Originally Posted by
Dyln.bxtr
Thanks for the help dude.
Just read about some fellas down in Sydney pushing out 400hp with boost in a k24. Would you be able to get 300hp (200kw) n/a if the same set up? I actually think they are on here somewhere.
This is the list I have got so far.
Engine - b18cr/k20a
Short rammed cold air intake
Head studs
Pistons.
Rockers.
Cam.
Sleeved.
stand alone fuel management.
Engine mounts.
Intake manifold.
Exhaust manifold.
Fuel pump
Fuel pressure regulator
Fuel filter
Fuel rail
Fuel injectors.
Spark plugs and leads
Distributor.
70mm throttle body
Map sensors
Radiator.
Fan.
S80 LSD transmission. 98 spec
Or 6 speed LSD trans
Short shifter.
