Wow great find ! Thankyou so much. This helps heaps !
Hey will 18x9.5 wheels fit on a dc5 ?
As previously stated, it depends on the offset.
If it's around the low 20's, you'll need to roll guards and cut/remove stuff
If it's around the high 20's, you MIGHT run into problems with it hitting the front suspension, and rear trailing arm.
If it's 30+, you'll hit the front suspension and rear trailing arm.
You really need to specify the following before people can tell you "if it'll fit"
- Rim size - Width and diameter
- Rim offset
- Intended tyre size
- Car ride height
- If you are willing to modify stuff to make it all fit
Wider, 17x9 +35 enkei rpf1 looks sexy. Anything 17x9 looks great saw some work cr kai that size looks great too
http://gripshiftslide.com/photos/CLUBITR/12.jpg
**** that frna guy never siezes to amaze.... all he ever writes is stupid shit with no justitiffcation.... some dc5's pending therio ride height will have issues with 9j+35.... **** just dont lsiten to that guy
