He is from philippines so I guess his english isnt advanced yet but usually we can help
you can check what sparkplug here also http://www.ngk.com.au/spark-plugs-pa...and-commercial
since you got 1996 civic d16y the plug is BKR5E-11 :)
daveh01 i tried that already but same problem its not giving power..
no every one that i talk here in OZ says my english is good but i just dont know the term for the problem.. sorry guys any of you have a skype or facebook so i can explain it very well on video..?
Your d16y engine is very weak so you cant just step on it with 5th gear at 80km and expect it to move fastly
it cant do that since its only 1.6litres and low horsepowers
you can change to 4th or 3rd gear if you need to :)
Here is your solution, instant torque ;)
http://www.ozhonda.com/forum/showthr...s-for-ED-EG-EK
its not the torque of the engine guys i can play the tranny or the shifting the way you explain but the engine isn't giving it its like it has a busted sparkplug or the air filter is clog the feeling of those two that was what i had experience..but as i have put it on neutral and rev it the engine sounds good its only when pushing it its like it is lacking on petrol or something.
Hmm well yes it can be air filter,plugs,fuel filter but we dont know for sure
put the new spark plugs anyway because its always a good start
you can visually inspect the air filter yourself to see if its dirty or not
ekvtir.. the link you posted i might try it because last night the check engine on my dash light then when i turn the ignition off and turn on again it was gone..
hmm you gave me an idea grifty.. im gonna check my fuel filter and pump because in hearing it thicking sound whe i put my ignition on..
