Yup, as long as the casing is intact I don't see why it won't work. Doubt you can pierce seals and what not with the limited access you had.
Ahhhh, if the seal broke and the gas escaped... Ask the suspension place before putting your coilover in for the overhaul what they think and estimated cost.
Check to see if they can rebuild using HKS parts or if possible order the HKS rebuild parts yourself.
Ahhhh HKS unwilling to all you to buy rebuild parts and have the guys here do it.
I found this regarding the Overhaul Service/Parts for the V Sport.
Like I said, as long as the guys doing the work here for you ensure they give you the same parts/gas/fluid and quality as HKS, you have nothing to fear =)
Its the other guys that can rebuild a set of coilovers for a fraction [like 60-70% less than official channel] that normally use sub-par parts than make the coilovers blow out within 3 mths...
Yup, google around for something like erm... Coilover Overhaul/Rebuild Australia, you'll get plenty of instances with sub-par rebuilds lol...
Just gotta be careful :)
