An update...
6. Remove the radiator cover from your car (refer to Step 1, in this guide). I pried out the radiator cover clips with with plastic prying tools.
7. Measure where the centre of the grill is and feed the emblem through the front of the mesh...you can see how hi-tech my measuring skills are
https://dl.dropboxusercontent.com/u/...e%20centre.jpg
8. Reach around the back of the grille and attach the washer, and then the nut.
https://dl.dropboxusercontent.com/u/...gh%20grill.jpg
https://dl.dropboxusercontent.com/u/...d%20washer.jpg
9. Done! (Quite honestly, if you want an even more finished look, you don't need to have the washer and nut behind the grille. There's already enough grip with the bolt going through the grille.
https://dl.dropboxusercontent.com/u/...e/09-final.jpg
https://dl.dropboxusercontent.com/u/...e/10-final.jpg
https://dl.dropboxusercontent.com/u/...e/11-final.jpg
looks really good but should paint the mounting hardware black just to finish it off nicely
