How come you are looking to rebuild?
Just want to know what the possible additional costs are like when buying a cheap s2k :)
Building back to oem spec - ~5k
The car's more likely to have been in accidents from the rear letting loose than have a dead motor.
If you were to buy a cheap s2k with engine troubles and spend 5k on a rebuild, would it not have been wiser to just spend the extra money on a good s2k to begin with?
http://www.ozhonda.com/forum/customa...ar29948_16.gif
that wise old owl
good excuse for engine swap
sr20 or 2 jay z
sr20? you cheeky kunt lol
sr20det i mean
not groce na
Highest were 215, lowest was 190 for a 122,xxx km one way past 5% differences. Currently about to check a 100,xxx hopefully I'll get better results.
To get a low km's 70,xxx k's could cost $22,000 and up and compression may not even be close to perfect. In contrast, I could get a cheap $15,000 one, use the engine until it fails and rebuild it, giving me a brand new engine. But this is assuming both chassis are straight etc., and the only difference are engine comp's.
So far it's difficult to find an S with decent engine comps, most of them have been flogged, burning oil etc. I haven't seen a bent chassis as of yet, regardless of mileage.
The engine comps might be off but if it doesn't lose much oil and drives well enough - would you really spend 5000?
You are buying an old car don't forget
