yeh just bought it off ebay for $50 hopefully i ca put a stop to the leaking vtec solenoid :)
thanks Jasemas and curtis265 again
yeh bought it on ebay hopefully it wont be too hard to install :/
Just a heads up when changing the solenoid
Do it with a dead cold engine - that way the little 10mm headed bolts are not weakened by heat , and there isn't a bunch of oil ready to leak out when you take it off. Take it easy on the bolts. Undo slowly and tighten slowly too. Finger tight + a nick up with a small socket or spanner should do it
Thanks @bennjamin
will keep those tips in mind
