Hmmm i believe its just the motor dying out...Quote:
it could be the rubber in the rail inside your door scrunching up... I found that was the case with mine.. the rubber had torn and was scrunching up slowing the window.
ah, gotta go check it out..
Dont think I can get the spray for you tonight (boyfriend had a minor whoopsy), but will get the name of it at least... Okay?? See a tonight
lol wen my pw windos got slow the kept geting slower then it soped half way down ............ had 2 get my motor for it lolz fun fun
Nuh not for me... A bit of spray and I was on my way!! :D THAT RHYMES hahhaa!!Quote:
Originally Posted by mojo the flashy monkey
hey guys my drivers side window has just come a little off center when i wind it up
it's power windows
what would cause this?
Yay I can answer this! LOL.
After I was hit up the rear end (keep mind out of gutter boys!) becuase my window was down on impact it shifted. Mechanics told me needed new motor as it only went half way down then kinda fell and shifted out of place. When my boyfriend took the door trim off, all it was was the window had come off the rails, he took the window out and realigned it and it works perfectly again!! :) Just more proof, never listen to a mechanic.
So answer to your question, it's probably come off it's rail or is shifted slightly on rubber or something else, take the door trim off and bob's ya uncle!!
thanks jes87s
just took the door trim off and it had come off the rails because the opposite side wasnt letting the window slide up very well
ive lubricated the oppostite side and put it on the rail and its working perfect
now to put the door trim back on is proving a little difficult hahaha
WOW I HELPED SOMEONE!! WOW!! lol this thread should go down in history!!
wuold wd40 work?
how much is the spray?
