ensure your distributor is not 180 degrees out (the end drive on the shaft held on by the pin) Compare it to your old dizzy
dizzy only go one way right? since the slit is offset
the dizzy can only go in one way, the drive on the dizzy shaft that mates to the cam locator can go on the dizzy shaft two ways.
Can u start the car by push starting? If so starter motor
just an update guys. I've been working a fair bit and havent had a chance to address this issue so I got my car towed to my mechanic. I will update when the issue is resolved incase anyone has a similar issue. Thanks for all the input though guys much appreciated!
