You can drive around with a MIL light in a OBDI car.
Dont think they had a "Limp Mode" like new cars do when it is a major issue
Pssht Perludes are gay.
Sorry i just assumed that all Honda's had o2 sensors.
natsrsaboutludes.
<3BB6
OBDI certainly goes into Limp Mode,
If you can rev past 4K RPM with the MIL on then you not if Limp Mode, the ECU is just reporting a fault and the main processor in the ECU is active. In limp mode a secondary processor runs a basic map that allows the engine to run with limited sensor input.
I get high in limp mode :P
OT
Did you get the MIL fixed?
of course it should be free! IF they knocked off a sensor then they better fix it!
Holy **** if theyre that ******* and do not know how to get a code from an odb1 honda ecu (google) then i would not let them near your prelude again
