There was a recall on the rear wheel bearings for the jazz
Or tsb
one of those
My bet is on Gearbox issue op.
S mode just tends to hold the gears for longer. Example, your going uphill and don't want the car to die down easily. Shift into S.
D will cycle through all the gears normally.
If the engine is working fine on a gearbox setting which stress's the engine out, it should work fine on D.
Therefore Something wrong with the gearbox?
Take it to a Honda Specialist instead of blowing money on trail and error at home.
My GE is fine
it was the gd chassis that had the rear wheel bearing tsb
I have exactly the same problem. I had bad cvt shudder but resolved with flush and reset (and oil extreme).
I suspect its a misfire and due to faulty coil. In S, the alternator is delivering more charge to electrical system. Will let you know how I go.
Hi all,
Thanks for your input.
I have now the problem solved.
Here's what I did:
I replaced the gearbox with a secondhand but guaranteed good condition gearbox. The problem was exactly the same!
So, this took me to my last option: The coil pack.
I replaced the 4 coils at the back with secondhand ones. Whilst I was doing this I also replaced the spark plugs.
Took it for a road test and the car was driving perfectly! All smooth, better acceleration and most importantly, no jerking anymore.
I bought 4 secondhand coils for $150.00 all in instead of $320.00 per unit as quoted by the Honda stealer.
There was no visible damage to see on the coils. All sparkplugs looked identical, so, I still don't know which coil played up.
I am of the opinion the coils must break down internally once they are warm/and under load.
Hopefully this information will be helpful to Jazz owners.
those damned coilpacks! FYI if you are not into secondhand ones, Repco does them for $90 per hit.
Hey mate,
What's usually found with this style of coil pack is the extension tube fails. Also we found this with both my own jazz and my mums!!
When checking the coil while out of the vehicle all could packs can test and look fine.
What we commonly find is the extension tube fails due to heat and age and the spark will jump to the plug tube bypassing the spark plug.
A quick fix/diag method is the remove the coils and wrap the extension tube very well with good quality electrical tape.
This will insulate the extension tube allow the current to continue to the plug.
Hope this helps!
Glad you got it sorted! See my post above - I replaced all coils - but no change :(.
Was thinking about a new (used) trans but saddened by your failed attempt. Might try the plugs and another flush - I really like the car but might have to get rid of it.
Got a new tranny - fixed.
Would recommend anyone with judder do the following:
Change trans fluid; ~$90
Clean EGR valve; ~$10
Replace spark plugs; ~$120
Replace coilpacks (ebay ones are ok) ~$150
And if all this fails your tranny is screwed. I beleive that it was not just transmission problems for me originally so dont feel I have wasted anything but some cvtf.
