I like getting spoon fed
HMMMM, no idea sorry, that's one of them movie stars isn't it?:o
So it's Samuel L Jackson out of Pulp Fiction, but I don't see how copulating with someones maternal parent will help me wire up my injun....:p
find yourself a copy of the DC2R service manual floating around, In the manual you will find the PGMFI schematic under the fuel section
AH HA, sorted thank you Man.
Is it still possible to buy new sensor and ecu plugs to save splicing the old stuff into a new harness?
Sure on your rules for rego? Sure it doesn't have to meet emissions standards?
When I was researching building kit cars the engine had to comply with an older version of the emissions standards. If that's not the case for you then awesome but it would suck if you got told the wrong thing until rego time...
Also re ecu. Get it running with stock stuff then rip out all the wiring and wire it all up from scratch. Don't stuff around with harness adapters and stuff. My thoughts anyway
Yes quite sure, I've already employed an engineer for the build and according to him (and others I've spoken to) any ADR 37/00 complied car (motor) can be used under the new NCOP rules for ICV's. These cars are already emissions compliant.
This is in Qld only though, other states, particularly NSW are different and more difficult.
In Qld the TMR is not involved at all any more besides paying your money and picking up the plates, the engineer now signs off on everything, it's a huge improvement for us.
For the harness issue, may I recommend looking at an ek4 harness. It's a one piece harness that runs directly to the ecu, not a half harness like the dc2's is.
But, if you're planning to run an aftermarket ecu, could be an investment to get an aftermarket engine look too. Some can plug directly into the obd1 and will look better too. They're more of a tucked hidden harness.
Thanks for the info, though I'll def make a new harness, hence why I asked about getting new plugs.
Trying to put 15-20 year old harnesses into a new, different shaped car if fraught with danger IMO, to many solder joints, loose ends, excess wire etc is a recipe for gremlins.
Making the harness is easy enough once you know what needs to be in it.
