sounds like the ECU does not want to engage VTS
is the ROM in the ECU stock ?
did you ground the other side of the test lamp for the VTS test ?
any DTC's in the ECU memory ?
You need to test the VSS, TPS, MAP and ECT signal at the ECU connectors.
you need to do voltage tests for ECT, TPS and MAP with a warm engine and frequency for VSS as described in the below links.
http://www.ozhonda.com/forum/showthr...cs-Code-17-VSS
http://www.ozhonda.com/forum/showthr...ics-Code-7-TPS
http://www.ozhonda.com/forum/showthr...ics-Code-5-MAP
http://www.ozhonda.com/forum/showthr...ics-Code-6-ECT
