I've got a 19 row oil cooler with -10AN lines, it's a Mocal not mishimoto but same dimensions. It is mounted in front of the radiator passenger side where the power steering cooler was (P/S removed). This is in a dc2 with standard full size radiator, there is plenty of room with A/C removed. You may need to experiment in the ej8. Also make sure if you are buying a kit that the lines are long enough to reach, dummy fit and trace where you want to route the lines before you buy.Quote:
Originally Posted by nijalninja;
It makes a difference if you are tracking the car, otherwise I don't think on the street you will need it. If I don't cover the cooler in normal street driving the oil temp won't get above 80deg C and I am still using the stock water/oil heat exchanger where the oil filter normally mounts. On the track temps are usually between 110-120deg C measured at the oil pan for 5-10 laps depending on ambient temps.
