Mate, go and re read the replies from hondarally and dread Angel they are spot on.
Your bc coilovers are never going to be "comfortable" no matter how many clicks you make on the damper. You can raise the height easily enough to avoid scrubbing if you want.
Your A050's will be screwed very quickly on the street. I'd be surprised if you got more than a few thousand usable kms left by your description of the current wear and alignment settings.
Daveho is right on the wheel alignment places unless your local franchise guy is extraordinary. Most will pretty much only adjust toe even if you specifically ask for camber adjustment. The usual answer is "nah you can't adjust camber" even when you walk over and point to the adjustment bolt. Who knows whether it's ignorance or just plain laziness on their behalf. You won't get a shop to do a full height camber and toe setup for your standard $50-$100 price. It's going to be more like double that price and by your requirements you will still be disappointed I think.
