Xforce downpipe dun have a cat. It works fine in our jazz but not the new jazz. I am thinking of getting my frd's xforce downpipe but I am wonder if i can fit a hiflow cat on the pipe. Anyone have any idea?
hmm..if i get a x-force cat back exhaust system as well..does that mean it'll be alrite??
TypeG - yes you can fit a cat in there....however you might as well just get an exhaust shop to make that whole part for you....it wouldn't be that hard.
Ours works fine because we don't have the sensor after the cat....but the risk of running no cat is too great ($10,000 fine)
asiansquad - the cat-back won't fix it.....you will still need a cat
oh..so even with cat back..we don't hve cat?
ah damn
nope..the cat-back will connect to the end of the down-pipe. You will need to install a cat in that down-pipe section.....
ahh...ok then..so the x-force downpipe that came with the header is basically useless
cant say its useless... if u wanna bring ur track to the track u can just chuck the xforce one in... or just put a cat on that downpipe.... i would say its definitely cheaper as only cutting and welding..... thats all... plus xforce quality isnt that bad either
Yep, just do what Zimp said.....I had a lo at your x-force headers when Adrian still had them and all you need to do is cut out the resonator inthe down-pipe and replace it with a cat. Done!
