I know there are aftermarket internal and external fuel pumps.
Which 1 is it for say a gen 2 crx?
yeh its a gen 2 crx
What if you don't have an injector rail :)
carby ???
So where would I put a fuel pressure meter?
hijacking a thread benj!... tsk tsk... jk:pQuote:
Originally Posted by bennjamin
yeh my civic does the same thing... :( will the fuel pressure gauge help determine if there
is a problem...? :confused:
on a carby you would measure the fuel pressure before the carbys on the fuel line, however carby engines react differently to fuel pressure problems. so this thread dosnt really apply to carb.
EFI is your fuel pressure is fluctuating, your engine will suffer from this.
if your fuel presure is constatnt and within specs, then you should start to look at your injecotrs or posibly even your ignition system.
to add....if perhaps i was to take out my injectors- and get them all pulse cleaned ( ir whatever its called at a workshop) woudl this rectify the problem ? ATLEAST find out if its the injectors clogging up etc ? ( this is on a 13 year odl car...with the same old injectors...)Quote:
Originally Posted by ECU-MAN
omg i have the same problem.Quote:
ARE FUEL PUMPS INTERNAL OR EXTERNAL FOR CRX's??!?!
all crx have internal fuel pumps
get a walbro pump ben.. cheap cheap and it'll giv eu more power
