Originally Posted by saxman
I still disagree on the kit part...
isn't part of having a low budget about getting the most for the amount of money you're spending? you'll always spend more money and get less with a kit. Infact, I think that it goes the other way around. For higher budget jobs, there are kits that could be effectively used(i.e. full-race), but for a low budget set up, you're just wasting money by buying a kit. If someone can't put together a kit to do the job, they probably shouldn't be turboing there car anyway.
low budget= no kit because it's cheaper to not get one
high budget= no kit because kits don't offer what is needed for the set up your after
As for just using the manifold from a kit, unless you're getting a really good deal, they tend to cost as much or more as a new, log manifold, which has been proven (assuming proper construction) to flow better and make more power. These days, there are so many options for manifolds out there, at such good prices, why waste the money on a used, more restrictive manifold?
