what kind of pod are you using?
I'm using a K&n
just give it a cold air feed
nothing wrong with the simota or the ebay piping.. if ur worried about heat absorption... just - spray it with the high temp spray which u use on ur brakes...
- wrap that thing up with sum thermo wrap (good stuff)
- leave it stock n use a panel filter n have a cold air feed to it.
Can you give me links or pictures where i can DIY Cold air intake for the 93 prelude, i know there is an airduct that is located underneath the stock airbox, but the way to run the pipe i have no idea..thanks
