thanks for that but how do i "crank" it? kinda noob with this stuff.... do i turn the car ON? or something else? completely lost here
arrgghh dont worry. Just turn it "over" - liek you would to start the car normally. The engine will make a " dun dunnnnn" noise and kep the key in the same position until it does it 5 or 6 times.Quote:
Originally Posted by **Ghost**
nice write up ben! top job
hahhahahahha rolf... thanks ben i'll do that!! : ) see u shoulda been more simple in the first place :pQuote:
Originally Posted by bennjamin
when my car was warm/cold(i left it for about 20 mins) i got 135 165 135 180. but when i redid the test after starting the car and made the engine hot it got pretty much 180 psi across all pistons.
so does the warm/cold reading mean anything??
where do u get said item in step 3? :p
i mite just get one lol
nice write-up. really appreciate it :-) especially the explanations given to ghost.
kristin
Nice write up Benj... get some pants! :p
i plan to do the test on a ZC tomorrow, is it hard to get the spark plugs out?
Ie. is the spark plug remover necessary to get them out?
this test work on carby engines?
tried it and the compression tester keeps sitting on zero for some reason...
well the problem was that the compression tester wouldn't screw in properly, still cant get it to
Which part wont screw in ? The actual head which goes into the engine/spark hole ? Or the top which connects to the gauge ? Try running alittle fresh oil around the head to "seat" it in - and make sure all the gauge lines and screws are tight. Good luck !Quote:
Originally Posted by michael_antoi
