dont use pot air filter!.......as for your car a drop in air filter + stock airbox is good enough!
Quote:
Originally Posted by SLPJCooL
Quote:
Originally Posted by **Ghost**
LOLOO
480ks around town if I drive nice(ish), probably push past 500 if I drive like a granny. That's with the fuel light on for a while, but I've yet to run out of fuel. I usually get about 550-600ks on the highway, and even then the fuel light has only been on for a little while.Quote:
So does that mean even if I did install a AEM CAI, it'll do jackshit in terms of Performance? Not even a single horsepower gain???Quote:
Originally Posted by Terry
i get about 250kms half tank....around town on my crappy oldhonda civic Si - only becasue it can breathe :) No clogged air/fuel filters and always with fresh plugs etc etc.
Also I have the stock airbox + a hi-flow air filter.
Nope...On a D16Y1, I regularly got over 500km per full tank, and that includes mad Vtec thrashing around. It was a completely stock engine with 200,000km on the clock.Quote:
im with ben my 'crappy' si gets like 350 to half a tank, ur guys cars arent that economical LOL
Hey Ben, How often do you change your Fuel Filter AND Plugs? Cos I think I have to start go "econ" on my Car, Fuel's just too damn expensive nowadays!!!Quote:
Originally Posted by bennjamin
:D Bump :D
Try to change a better plugs...and check your distributor setting...
Well why don't you put the car back to the same oil and see if the fuel consumption is any better. Synthic oils are meant to reduce friction and increase milage. I don't think this would cause you to use more fuel. Unless you are ripping every time you take off.
I know if i keep my engaged in Vtec all the time it certainly drinks fuel. On the hwy i got 600km on a tank, generally get about 450 - 500km per tank in my ek4
