Yeah it is a fairly simple process once you no it. For a first timer however, it may prove difficult.Quote:
remember to have lots and lots of fuses when u do it by urself and not disconnectin the battery...:D
DIY! It's the only way!
Just finished reading the ID tutes, and its plainly obvious that the panels in the AUD civics are slightly different, the two screws they say are near the cigerette lighter are in fact in the ashtray roof. I've pulled down the EK dash a couple times now and its a work of art if you do it in steps and put it back the opposite you can't go wrong.
When ever your doing major install its always much easier and save plenty of bruised nuckles if you strip out almost the whole interior.
diy! = more $ in pocket baby!
I'm pretty sure this has been covered in the forums, i removed the glove box, panel underneath the steering wheel, and slid the centre section back. I then removed the centre section, and unbolted the stereo from underneath.
once u take off the panels and the glove box, if you havent got the headunit keys to pull out hte head unit, i used a flat head screwdriver to push in the clips from both sides and pushed my headunit out from the back.
