This cant be true. Hook up a test light in cabin and check it this way.Quote:
Originally Posted by VT3C
You'll see what i'm talking about.
Ive datalogged this many times also, so it is true. Low load & high load are in fact different.
There is also usually a discrepancy between actual activation & cluster rpm's!
This sensation is because honda typically run the x-over point quite rich.Quote:
The Butt-dyno will sence power at this point becuase the transition between rich to lean will always generate HP.
hehe, vtec rocks!Quote:
