Can't imagine they would do heaps, but I am sure you will be able to feel a bit of difference. Coz the front is already fairly stiff. But I am getting some anyways sometime soonish, once I have sorted out a few other things :D
so wot order should i get em in?
if you really want a stiff chassis, go get some rollcage..
i have front and rear strutbar, floorbar, b-pillar, custom trunkbar, and swaybars but i still dont find it stiff enough..lol
or if you dont want rollcage, add a z-bar that connects to you c-pillar-rearstrutbar and trunkbar.. (emracing or memoryfab make them)
I think you should do it in this order:
1) Front Strut
2) Rear Strut
3) Rear Swaybar
4) C Pillar Bar
5) Front Swaybar
6) B Pillar Bar
7) Floor Bar
8) Fender Brace
But it all depends on convenience. The only reason I put C pillar before B pillar is because it doesn't effect people trying to get into the rear seats.
rear lower tie bar
front lower tie bar
we've been talking on the california sol board about the possiblity of using an expanding foam injected into the frame rails on our cars. This is a rather common modification among the old ford mustang owners... basically consists for using a two part expanding foam thats meant for chasis reinforcement being applied into the hollow frame rails, reinforcing them from flex. On the del sol's especially, the flex that causes the problems is from the front to the back of the car, not side to side, so all of these pillar bars, floor braces, etc are worthless
also, keep in mind adding braces isn't necessarily better. I ran at a test and tune day at the track(autox, not drag) and was consistently running about a second and a half faster WITHOUT a rear strut tower bar than with it in.
I would personally do it in this order (based on most effective first)
Quote:
- Rear Swaybar with tiebar
- Rear Strut (if hatch, otherwise swap with #3)
- Front Strut
- Front Swaybar
- C Pillar Bar
- B Pillar Bar
- Floor Bar
- Fender Brace
would you see a need to upgrade the oem front strut bar on a integra ?
wanna make it stiffer just got the swaybar thinking the rear strut and then on from there
With regards to the foam how durable is it? I have read that after a period of time more foam needs to be injected as it shrinks.Quote:
Originally Posted by saxman
there is foam designed specifically for injecting into a chasis for this purpose. I haven't ever heard anything about it shrinking, in fact the way it works, I really don't think you could even inject more foam if you wanted to.Quote:
Originally Posted by Fr3aKi3
you are running a rear ITR swaybar?? are you sure the sound you are hearing isn't the bar ripping your subframe??
hmmm to counteract that - you should invest in a trunk bar and C pillar bar.
see, I disagree... the proper way to counteract the subframe tearing out is by properly reinforcing itQuote:
Originally Posted by type one
